vicvo
scatterplot of adjusted effect for one predictor in a generalized regression model
I used generalized regression with LASSO for variable selection. The reduced model now includes 3 predictors. How could I make a scatterplot of the effect of one predictor adjusted for effects of other two predictors in the model? Thank you!
Re: scatterplot of adjusted effect for one predictor in a generalized regression model
You can define the model with the selected predictors again by selecting Analyze > Fit Model but choose Standard Least Squares for the fitting personality. (It is the default when you start.) Select Effect Leverage for the Emphasis. The leverage plots are the conditional plots for each term.
