jm
jm
how to plot an equation
I'm a new user to JMP and I have a simple question to seek your help.
I would like to ask JMP to plot a graph using an input equation, how do I do that?
The equation is as follows:
(c1-constant1)/(constant2 - constant1) = (constant3 * c2)/(1-(1-constant3)*c2)
where c1 and c2 = column 1 and column 2 respectively.
i.e. I have two columns of experimental data (column 1 and column 2) and ultimately I would like to plot column 1 against column 2 and fit it using the equation above.
Thanks for the help!
Jeff_Perkinson
Re: how to plot an equation
Xan's on the right track for you here.
The Nonlinear platform will fit your equation, finding values for your parameters.
To start, you'll need to move all your parameters ("constants") as you described them, to one side of your equation. Essentially, you'll solve your equation for either C1 or C2.
I solved it for C1 here:
c1 = ((constant3 * c2)/(1-(1-constant3)*c2) * (constant2 - constant1)) + constant1
Then, in your existing data table create a column for a new "Predicted C1", using the Parameters option in the upper left of the Formula Editor to create your "constants".
 Finally, use the Analyze -> Modeling -> Nonlinear menu to get to the Nonlinear platform.
You'll put your "Predicted C1" column in X, Predictor role, and your original C1 column in the Y, Response role.
Read more about the Nonlinear platform in the online documentation.
-Jeff
ron_horne
hi jm,
i would try to put each side of the equation as a new formula column. Then use the profiler and put both columns in the "Y, Prediction formula". Under the Graph menu there are a few different profilers you can choose between according to what gives you a better picture.
ron
XanGregg
To see c1 against c2. Make c1 into a formula column expressed as a function of c2. Then in Graph Builder, put c1 on the Y and c2 on the X and change the element type to the Formula element (second from right). It will plot a smooth curve of the function, not just the data points.
jm
jm
Thanks, that helped!
The plot now shows a curve of the function, together with my data points.
Supposed I can only enter an initial guess for constant 1, how do I ask JMP to start with the initial guess value and continue iterating until the Chi Square does not change for a certain number of iterations or the percent change in the normalized Chi Square is less than the Allowed Error set by me?
Would need the final value of constant, Chi Sq and R value at the end of the curve fit for my data points...
XanGregg
I didn't realize at first that your "constants" aren't really constants! I think you can get what you want if you update your formula to change the constants to "parameters" and then use the Nonlinear platform to find the optimal settings for those parameters.
Jeff_Perkinson
-Jeff
