ExcitedOwl
how to number rows based on column values
Hi All,
I have a table with SN and timestamp for each. I need to number the lines per each SN based on timestamp.
the table is sorted by time and I wanted to use ROW() with grouping by SN, but i don't know how to do it.
appreciate your help,
Thanks
Re: how to number rows based on column values
Here is the formula that I normally use
Col Cumulative Sum( 1, :SN );
@jthi  did something similar with ColSum(); here's an explanation of how it works:
https://community.jmp.com/t5/Discussions/Countif-equivalent/m-p/664313/highlight/true#M85267
Level XIII
If you cannot guarantee that the entries are sorted, use
Col Rank(:START_TIME_UTC,:SN)
