r30363
how to make cumulative probability plots in JMP?
How can I make cumulative probability plot like the one below? Appreciate your help.
36 REPLIES 36
Re: how to make cumulative probability plots in JMP?
Level XIII
There is also a nice way via Graph Builder:
First select the grouping parameter
then use the (right click) context menu/Distributional/ cumulative probability function to  generate the ColRank/ColNumber equation and put it on the y axis (the value itself on the x axis).
that's it:
Data Table( "Big Class" ) << Graph Builder(
	Size( 534, 464 ),
	Variables(
		X( :height ),
		Y(
			Transform Column(
				"Cumulative Prob...ty[height][sex]",
				Formula(
					Col Rank( :height, :sex ) / (Col Number( :height, :sex ) + 1)
		Overlay( :sex )
	Elements( Points( X, Y, Legend( 11 ) ), Smoother( X, Y, Legend( 12 ) ) )
Georg
As I'm using this quite often, I've implemented a simple script in custom menue (view --> customize --> menues and toolbars),
running it with a table open it makes the CDF Plot quite easily.
Oneway( all graphs( 0 ), CDF Plot( 1 ) );
Georg
r30363
Holger, thanks for the instruction, that is a new analysis skill which I am completely unaware. further question, if I want to do Left side  Y-axis with standard deviation, right side Y-axis with cumulative probability, how to add a right Y in graph builder?
Level XIII
is this what you mean?
Graph Builder(
	Size( 688, 430 ),
	Graph Spacing( 5 ),
	Variables(
		X(
			Transform Column(
				"Normal Quantile [sigma]",
				Formula(
					Normal Quantile(
						Col Rank( :height, :sex ) / (Col Number( :height, :sex ) + 1),
						0,
						1
		X(
			Transform Column(
				"Cumulative Prob [1=100%]",
				Formula( Col Rank( :height, :sex ) / (Col Number( :height, :sex ) + 1) )
		X( :sex ),
		Y( :height ),
		Overlay( :sex )
	Elements( Position( 1, 1 ), Points( X, Y, Legend( 17 ) ), Smoother( X, Y, Legend( 18 ) ) ),
	Elements( Position( 2, 1 ), Points( X, Y, Legend( 11 ) ), Smoother( X, Y, Legend( 12 ) ) ),
	Elements( Position( 3, 1 ), Box Plot( X, Y, Legend( 16 ) ) )
Level XIII
I really like Georg's approach to add a shortcut to the main menu.
My new universal plot button (best: with normal prob. scale :)
On the other hand, the GraphBuilder version with the individual data points provides more interactivity.
How would you adjust such graphbuilder code such that it can be used dynamically for any table like Georg's one:
The user should have the possibility to dynamically choose the variable to plot and the grouping variable.
For X, Y and Overlay, I can just use the Application Builder - but how to implement it for the Transform Column inline Formula?
Here is a crude example that should provide you a good start on what your idea is
dt = // Open Data Table: big class.jmp
// → Data Table( "big class" )
Open( "$SAMPLE_DATA/big class.jmp" );
New Window( "Select column",
	hlb = H List Box(
		clb = Col List Box(
			dt << get name,
			all,
			max selected( 1 ),
			Try( vlb << delete );
			hlb << append(
				vlb = V List Box(
					var = (clb << get selected)[1];
					Eval(
						Substitute(
								Expr(
									cp = Graph Builder(
										Size( 688, 430 ),
										Graph Spacing( 5 ),
										Variables(
											X(
												Transform Column(
													Formula(
														Normal Quantile(
															Col Rank( __var__, :sex ) / (Col Number( __var__, :sex ) + 1),
															0,
															1
											X(
												Transform Column(
													Formula( Col Rank( __var__, :sex ) / (Col Number( __var__, :sex ) + 1) )
											X( :sex ),
											Y( __var__ ),
											Overlay( :sex )
							Expr( __var__ ), Parse( var )
Level XIII
wow, that's very cool :)
I added a second ColListBox for the grouping variable.
dt=Open( "$SAMPLE_DATA/big class.jmp" ); dt << Clear Column Selection(); updatePlot = Function( {}, If( Length( clb << get selected ) == 0 | Length( clb2 << get selected ) == 0, Print( "value missing" ), var = (clb << get selected)[1]; groupByvar = (clb2 << get selected)[1]; Try( vlb << delete ); hlb << append( vlb = V List Box( Eval( Eval Expr( cp = Graph Builder( Size( 724, 560 ), Show Control Panel( 0 ), Variables( X( Expr( Name Expr( As Column( var ) ) ) ), Y( Transform Column( "Cumulative Probability[1=100%]", Formula( Col Rank( Expr( Name Expr( As Column( var ) ) ), Expr( Name Expr( As Column( groupByvar ) ) ) ) / ( Col Number( Expr( Name Expr( As Column( var ) ) ), Expr( Name Expr( As Column( groupByvar ) ) ) ) + 1) ) ) ), Overlay( Expr( Name Expr( As Column( groupByvar ) ) ) ) ), Elements( Points( X, Y, Legend( 7 ) ), Smoother( X, Y, Legend( 8 ), Method( "Savitzky-Golay" ), Lambda( 2 ) ) ), SendToReport( Dispatch( {}, "Cumulative Probability[1=100%]", ScaleBox, {Scale( "Normal Probability" ), Format( "Best", 12 )} ) ) ) ) ) ) ); ) ); New Window( "grouped Comulative Probability", hlb = H List Box( V List Box( clb = Col List Box( all, <<Set Data Type( "numeric" ), max selected( 1 ), updatePlot() ), clb2 = Col List Box( all, max selected( 1 ), updatePlot() ) ) ) );
Level XIII
The approach "delete the plot and replace the plot" makes it really easy to generate reports with complicated interactions :)
The only disadvantage:
By overwriting the old plot, I also reset all changes that I made to the original plot in the meantime (axis scaling, local data filter, ...)
As an interim solution, I searched for the changes and applied them to the new plot, e.g.:
dt =Open( "$SAMPLE_DATA/Big Class.jmp" );
gb = dt << Graph Builder(
	Graph Spacing( 5 ),
	Variables( X( :sex ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 5 ) ) )
// manal change like :
Report( gb )[Axisbox( 2 )] << Min(-100)
//read the oldvalues
mymin=((report(gb)<< xpath( "//AxisBox" ))[2] << getscript())["Min"]
//replace the plot ....
//apply the settings to the new plot Report( gb )[Axisbox( 1 )] << Min( Eval(myMin ))
Further thinking in this direction:
Is there a possibility to send a message to change the content of the plot?
Seems so ...
gb << Variables( X( :sex ), Y( :height ) )
is almost what I need, but it adds a plot instead of replacing it.
Is there an option for the "variables" messages to tell GraphBuilder to replace the old variables with new ones?
