SeanJYsh
how to import multiple excel files sheets with subfolder/file name/sheet name lables with "JMP import multiple files function" ?
Is there a way to import multiple excel files with more than one sheets in each excel files ? additionaly, is it possible set subfolder name of each excel files,file names and sheet names as labels ?
Attachments are the raw data and file path for simulation.
thanks!
Re: how to import multiple excel files sheets with subfolder/file name/sheet name lables with "JMP import multiple files function" ?
the Multiple File Import() function handles all of your questions except for placing the complete file path(subfolder name).  It can only add the file name as a column value.
SeanJYsh
Got it,Thanks!
