aczura
how to get a type 3 fixed effects test table
Does anybody know how to get a type 3 fixed effects test in JMP using the Fit Model option? I have a continuous response variable and a categorical predictor. I need a table that lists the denominator degrees of freedom for the F value. It should be a table that comes with the name Fixed Effect Tests. Please help!
Victor_G
Re: how to get a type 3 fixed effects test table
Hi @aczura
You already have created a post in the same topic, with a response from a user : https://community.jmp.com/t5/Discussions/how-to-get-fixed-effect-tests-table-to-appear/m-p/703000
Can you check and see if the response is answering your question ?
Victor GUILLER
