fbm73
how to find and replace all instances of specified characters within a given column
This is a very simple question.  I have a given column in a JMP table, and I want a JMP scripting command that will find and replace all instances of specified characters within that column.  For example, I have a column called GROUP, and certain rows in GROUP contain values like "A05 or "B17 and I would like to replace all " characters in GROUP so that the entries become A05 and B17 instead of "A05 and "B17.  This can easily be done manually by going to Table - Search - Find and then doing a find and replace, but is there a simple way to script this?
alecpena
Re: how to find and replace all instances of specified characters within a given column
You can use Recode to do replace in your jmp table. Before you submit it you can then grab the script to use in the future.
dt << Begin Data Update;
dt << Recode Column(
	dt:GROUP,
	{Map Value( _rcOrig, {"\!"A05", "A05", "\!"B17", "B17"}, Unmatched( _rcNow ) )},
	Target Column( :GROUP )
dt << End Data Update;
fbm73
Thanks for that reply.  Maybe I am mistaken, but I thought Recode can be used to replace entire, known values with different values.  But in my case, to be more specific, the values of GROUP can be like "A05, or "B17, or anything of the form "***, where all I know is that the value starts with a " character and then the * characters are wildcards which could be anything.  Really all I want to do is just strip the " out of the values.
Here is a simple piece of JSL that will handle your A05 issue
foundRows = dt:yourColumn << get rows where( Contains( :yourColumn, "A05" ) );
If( N Rows( foundRows ) > 0,
	:yourColumn[foundRows] = "A05"
pmroz
To remove quotes loop over the rows and use the substitute function.
dt = New Table( "Test Quote Removal", Add Rows( 4 ),
	New Column( "Group", Character, "Nominal",
		Set Values( {"A05", "\!"A06", "\!"A07", "A08"} )
for (i = 1, i <= nrows(dt), i++,
	dt:group[i] = substitute(dt:group[i], "\!"", "");
