fbm73
JMP script - Color or Mark by Column
I have a JMP table with a column called Order that contains letter values like A, B, C, D, E, etc., and another column called Number that contains number values like 1, 2, 3, 4, etc.  Manually operating on this table, I could do the following:
-- Right click at the upper left of the table and select Color or Mark by Column
-- Select Order from the list of columns, then leave Colors = JMP Default and Markers = None, then click OK
-- Select Number from the list of columns, then set Colors = None and Markers = Standard, then click OK.
The result of this is to assign colored symbols to all the rows according to the values of Order and Number.  How is a simple way to script this up in JSL?  And if possible, rather than setting Colors = JMP Default in the 2nd step above, how could I choose a specific color to use for each of A, B, C, D, E, etc.?  Thanks.
pmroz
Re: JMP script - Color or Mark by Column
Make a small table with colors and markers that you want, and then click on the red triangle > copy table script.  Paste it into a JSL window and you'll have an idea of what to do.
