ChernoffTurtle7
how to delete the Linked between Subset and original dataset?
hello,
it's cool to use Data View on selected rows to generate a desired subset. But then, how to quickly delete the Link between subset and original dataset? Otherwise, any operation on subset will automatically sync on original data. My JMP version is 16.1. Thank you!
Re: how to delete the Linked between Subset and original dataset?
To my understanding you cannot (currently) do that (you could create new subset which isn't linked. linked data table: how to cut the "link"? and wish list item functionality to cut the connection between a linked table and the main table
