Gacem_Seyf
how to create Pareto plot like the following image ?
hello I'm bigginner in using Jmp , I need to create Pareto Plot with the t-value of effect  and the Bonferroni and t-value limits like the following image .
Pareto-chart-showing-effects-of-factors-above-and-below-the-Bonferroni-Limit-absolute.png
Thanks .
Re: how to create Pareto plot like the following image ?
Creating bar chart in JMP with reference lines and labels is easy. It might be more difficult to figure out where you can get those specific t-values calculated. Good starting point on how to use JMP (in my opinion) is checking out the help documentation https://www.jmp.com/support/help/en/17.2/, there are also a lot if different videos in community.
This is just an example (I searched scripting index for Bonferroni and used the report the example script creates):
I can make the results into data table
Add some extra columns (rank), set labels (column and rows)
Create bar chart with reference lines
