GgGgGg2024
If function when checkBox is checked and unchecked
//Define Function1
Function1 = Function( {}, // Code for function 1 goes here Print("Checkbox is checked! Function 1 executed."); ); // Define function 2 Function2 = Function( {}, // Code for function 2 goes here Print("Checkbox is unchecked! Function 2 executed."); ); // Create a new window nw = New Window( "Checkbox Example", << Modal, // Add a checkbox to the window cb = Checkbox( "Toggle Function", Value( 0 ) ) ); // Add an OK button to the window nw << Append( Button Box( "OK", // Function to execute when OK button is clicked <<Set Function( Function( {this}, If( cb << Get Selected(), Function1(); // Call function 1 if checkbox is checked , Function2(); // Call function 2 if checkbox is unchecked ); // Close the window after execution Close( this ); ) ) ));
Hi, The code above is similar to what I am trying to do. I have a check box, and if I select it, and then click ok, function 1 should be displayed; and if i do not select it and click ok, function 2 should be displayed.
Re: If function when checkBox is checked and unchecked
Very easy to test by just trying it
a = function({}, {Default Local},
	Show("a");
b = function({}, {Default Local},
	Show("b");
func1 = function({input_value = 1}, {Default Local},
	Match(input_value,
		1, a(),
		2, b()
func2 = function({}, {Default Local},
	Show(2)
func3 = function({}, {Default Local},
	If(window:cb << get,
		func1()
		func2()
nw = New Window("",
	window:cb = Check Box({""}),
	Button Box("OK",
		func3();
I would start testing something like this without the check box and new window as those just add extra layer of complexity. You have to first be able to solve how functions work together before you start adding them to check boxes and so on.
That script looks like it has been created by ChatGPT or something similar and it does have few issues. Below is example which should work
func1 = function({}, {Default Local},
	Show(1)
	Show(2)
nw = New Window("",
	Button Box("OK",
			func1()
			func2()
GgGgGg2024
You are absolutely correct.
Can i nest a function? (write a function within a function)
CheckBoxHandler = Function ({cb},
	If ( cb << Get,
		//Call function with apple/banana if checkbox is checked
		checkedbox ()
		//Else
		//Call function with mango/watermelon if checkbox is not checked
		uncheckedbox ()
//Function 1 - box is checked
checkedbox = Function ({},
	Match ( x,
			"a", callapple,
			"b", callbanana
//Function 2 - box is not checked
uncheckedbox = Function ({},
	Match (x,
			"a", callmango,
			"b", callwatermelon
I need to add a match function in the [ Button Box ("OK",  ] command
	Show("a");
	Show("b");
	Match(input_value,
		1, a(),
		2, b()
	Show(2)
		func1()
		func2()
nw = New Window("",
	Button Box("OK",
		func3();
