newbie_alex
how to convert column names to a list of strings
I would like to convert column names to strings but I do not know how.
dt = Open( "$SAMPLE_DATA/Decathlon.jmp" );
col_names = dt << Get Column Names();
Show(col_names);
this leads to
col_names = {Name, Country, Score, Name("100m"), Long Jump, Shot Put, High Jump, Name("400m"), Name("100m hurdles"), Discus, Pole Vault, Javelin, Name("1500m")};
I would like to have something like this instead:
col_names = {"Name", "Country", "Score", "100m", "Long Jump", "Shot Put", "High Jump", "400m", "100m hurdles", "Discus", "Pole Vault", "Javelin", "1500m"};
Any idea?
Thank you for your help!
ian_jmp
Level X
Re: how to convert column names to a list of strings
Try '<< getColumnNames("String")'.
Look out for the editor tooltips that pop up for coloured keywords, or use 'Help > Scripting Index' to dig deeper.
20 REPLIES 20
ian_jmp
Level X
newbie_alex
Thank you!
newbie_alex
Is there something similar for Get Variables() ?
gb = Graph Builder( Variables( X( :height ), Y( :weight ) ), Elements( Points( X, Y ), Smoother( X, Y ) ) );
gbb = Report( gb )[Graph Builder Box( 1 )];
gbb << Get Variables();
mela_ssa
Try adding String as the argument of the Get Column Names function.
For example:
col_str = dt << Get Column Names(String);
It results in
mela_ssa
Try adding String in the Get Column Names function. For example:
It results in
If you are looking to get what variables were used Post Hoc to the platform being run, you can always extract the script used for produce the platform, and to examine it to get the variables
obj = Graph Builder(
	Variables(
		X( :Sex ),
		Y( :Height ),
		Group X( :Age )
	Elements( Box Plot( X, Y ) )
t = obj << Get Script;
Show( t );
newbie_alex
Thank you for the feedback.
The idea is to use JSL to do something with the list of graph variables (e.g. check what color was assigned by graph builder for a given variable (which do not know how to do yet)) and use the result to do something else (e.g. make sure that the same color is used in another graph).
Parsing the whole graph builder script returned by Get Script to determine the list of variable names seems to be a fairly complicated way of doing this.
// you could extract the x and y labels if you think
// these might have remained as the variable names
yvar=report(gb)[TextEditBox(3)]<<get text;
xvar=report(gb)[TextEditBox(2)]<<get text;
ian_jmp
Level X
Following Jim's thinking, maybe something like?
// Make a Graph Builder report
// Post-hoc interrogation of the report . . .
// (1) Get the script that launched the platform (or do: ' sc = gb << getScript')
sc = (Report(gb) << getScriptableObject) << getScript;
// (2) Pick apart the script expression and get what's needed
varList = {};
for(i=1, i<=Narg(Arg(sc,1)), i++,
	InsertInto(varList, Arg(Arg(Arg(sc,1), i),1));
Print(varList);
The code is a little terse, but you can use 'Help > Scripting Guide' to see what at 'Arg()' and 'NArg()' do.
