Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
I am working on the Graph Builder and by mistake I changed the error bars, so that only the top and bottom are visible. The vertical connection line is still there, but very thin. I want to make it the same as the caps. Any ideas how?
Created:
Sep 15, 2016 03:34 AM
| Last Modified: Oct 18, 2016 9:02 PM(6172 views)
| Posted in reply to message from leymann1 09-14-2016
I'm not completely sure how this happened. In general you can adjust the line with of the complete error bar by right-clicking into the graph => Customize => Error Bar => Line Width
Maybe changing the line width in there helps.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '20399' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '20399') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '20399') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
