I am working on the Graph Builder and by mistake I changed the error bars, so that only the top and bottom are visible. The vertical connection line is still there, but very thin. I want to make it the same as the caps. Any ideas how?
Created:
Sep 15, 2016 03:34 AM
| Last Modified: Oct 18, 2016 9:02 PM(6178 views)
| Posted in reply to message from leymann1 09-14-2016
I'm not completely sure how this happened. In general you can adjust the line with of the complete error bar by right-clicking into the graph => Customize => Error Bar => Line Width
Maybe changing the line width in there helps.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '20399' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '20399') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '20399') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
