Special Characters substitution in column names
Hello All, I am trying to substitute a simple underscore ( _ ) into each column name that has any conceivable "special" character without having to do individual if statements for each character.
Say column 1 is labeled Test1%good#parts, column 2 is labeled Test2*Fail#Opens, etc
I want the renamed column names consistent- Test1_good_parts, Test2_Fails_Opens, etc.. The data in the columns are counts (numeric and continuous or ordinal).
I've tried versions of:
spec_char = or(" ","~","`","!","@","#","$","%","^","&","*","(",")","-","+","\","|","[","[","]","<",">","?","/","."  // no underscore here
dt = current data table();
col_name_list = dt<< get column names( string );
nc = N Cols( dt );
For( i = 1, i <= nc, i++,
  one_col_name = col_name_list;
  If(
  Contains( one_col_name, eval(spec_char) ),
  Column( i ) << set name( Substitute( one_col_name, eval(spec_char) , "_" ) )
But rep is a pattern where eval(spec_char) is looking for a character.
Is there a clean way to perform this type of group substitution?
Thanks.
Re: Special Characters substitution in column names
Here is a script that will do what you want:
dt = Current Data Table();
colnames = dt << get column names( string );
For( i = 1, i <= N Items( colnames ), i++,
       wordcount = 1;
       thenewcolname = "";
       While( Word( wordcount, colnames, " !@#$%^&*()-+[]<>?/\|" ) != "",
              If( wordcount > 1,
                     thenewcolname = thenewcolname || "_"
              thenewcolname = thenewcolname || Word( wordcount, colnames, " !@#$%^&*()-+[]<>?/\|" );
              wordcount = wordcount + 1;
       Column( dt, colnames) << set name( thenewcolname ) ;
ms
Super User (Alumni) ms
The Regex function should work well for this:
For(i = 1, i <= N Col(dt), i++,
    Column(dt, i) << set name(Regex(Column(dt, i) << get name, "\W", "_", GLOBALREPLACE))
       wordcount = 1;
       thenewcolname = "";
              If( wordcount > 1,
ms
Thank you both MS and Jim, both work very smooth!
Rob M.
