odoyle81
how to change default summary statistics displayed in distributions
How do I change the default summary statistics displayed when using the Analyze / Distributions tool?
Obviously once you are in the distribution results, you can click the red triangle and select "Customize Summary Statistics" but that only changes the summary statistics for that item.  I need a way to always sure certain summary statistics.
Re: how to change default summary statistics displayed in distributions
You can set the summary statistics that you see every time using Preferences. Go to File > Preferences > Platforms > Distribution Summary Statistics.
Best,
Michael
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
Best,
Michael
Michael Crotty
JMP Development
odoyle81
Thank you so much!  I looked in "Distribution" but didn't scroll down to the next item in the preferences
