Sagiotogo
how to calculate / view Semi-partial correlation?
hey all
I'm trying to figure out how to calculate/view Semi-partial correlation in JMP PRO 16, and google can't seem to know either.
this is the question and the data, question number 4.
Re: how to calculate / view Semi-partial correlation?
The discussion area is generally not intended to answer homework questions. Also, questions are generally about JMP. See the help for the Multivariate platform for your answer.
Byron_JMP
I can't remember seeing "Semi-partial Correlation" anywhere before.
I'm pretty sure your TA is completely messing with you.
...or it was something mentioned in the lecture.
