ReliabilityWolf
how to apply variable to custom SQL
in custom SQL, this works.
.....left join  c
on d.SCU = c.CU
where d.DE in (' 216532','216534')
in script, I define a variable: inString = ' 216532','216534'
then I like to run custom SQL:
.....left join  c
on d.SCU = c.CU
where d.DE in (' inString')
but i doesn't work. how do I use my variable in custom SQL correctly?
Re: how to apply variable to custom SQL
You can use Eval Insert()
inString = "'216532','216534'";
sql_template = "\[
	.....left join  c
on d.SCU = c.CU
where d.DE in (^inString^)
sql_str = Eval Insert(sql_template);
sql_template = "\[
	.....left join  c
on d.SCU = c.CU
