JeromeH
how do i create a customized tabulate table adding free text comments summary
I am building a reporting table where I aggregate statistics for different production campaign, I would leave the opportunity to user to add free text descriptive comments, for each campaign.
I tried one way by adding text column "comment" to my  data table, where user can add multiple comment at different rows  (different moment of the campaign).
I used the tabulate option in my script to generate the stats. I can not find the way to easily add the free text comments in tabulate table (I was thinking concatenating the different comments/character strings into one comment/summary for each campaign)
Scrolling the community, one way might be to create a similar table box, with more flexibility to add an additional row with free text comments? I must admit it starts to be over my scripting skills:-)
working on JMP 16.
my test table looks like that
and the classic tabulate script is here
Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Grouping Columns( :Campaign ID ) ),
		Row Table( Analysis Columns( :U.R24, :E401.Run, :LVL.BED.R24 ), Statistics( Mean ) )
	Local Data Filter(
		Add Filter(
			columns( :POLY.GRADE ),
			Where( :POLY.GRADE == "PPK0132F" ),
			Display( :POLY.GRADE, N Items( 15 ) )
Re: how do i create a customized tabulate table adding free text comments summary
You could use GROUP_CONCAT with SQL-query to get comments concatenated. Here is example using Big Class:
dt_concat = Query(
	Table(dt, "t1"),
SELECT sex, GROUP_CONCAT(name)
FROM t1
GROUP BY sex
dt << Update(
	With(dt_concat),
	Match Columns(:sex = :sex)
dt << Tabulate(
	Show Control Panel(0),
	Add Table(
		Column Table(Analysis Columns(:height, :weight), Statistics(Mean)),
		Row Table(Grouping Columns(:sex, :"GROUP_CONCAT(name)"n))
Depending on the use, I would most likely prefer using Summary table instead of Tabulate.
dt_concat = Query(
	Table(dt, "t1"),
FROM t1
GROUP BY sex
dt << Update(
	With(dt_concat),
dt << Tabulate(
	Add Table(
