rs
rs
how do a number sequence to unique values?
I have the  following Column1 and need to create a new column containing the sequential number of repetitions in Column1
Column1
a
a
a
b
b
c
The resulting table should look like this:
Column1Column2
a1
a2
a3
b1
b2
c1
Any suggestions how to code in in JSL? (or in column formula?) thank you!
gzmorgan0
Re: how do a number sequence to unique values?
Here is a column formula method:
// define values
Col1Vals = {"a","a","a","a","b","b","c","c","c"};
dt = New Table();
dt << New Column("MyValues",Character,Nominal,<< Set Values(Col1Vals));
// Create Cumulative Frequencies
dt << New Column("CumulativeFreqCount",Numeric,Continuous);
dt:CumulativeFreqCount << Set Each Value(
If(
	Row() == 1, 1,
	:MyValues == Lag( :MyValues, 1 ), Lag(:CumulativeFreqCount, 1 ) + 1,
	1
)); // end set each value
uday_guntupalli
Level VIII
@rs ,
 Assuming you have a reference to the data table - let us say dt :
dt1 = dt << Summary(
	Group( :Column 1 ),
	Freq( "None" ),
	Weight( "None" )
If the data is not sorted (typically it should), then you can use the sort() on the resulting table
Best
Uday
rs
rs
thank you.  I put the code into a JMP script file (see attachment) but the script does not run.  Any suggestions?
Would be easier to put the code in a column formula?
uday_guntupalli
Level VIII
Actually, I missed the part where you wanted to get a cumulative sum, rather just the sum.
I am pretty sure there is smarter and more efficient ways to do this. This will work though.
I am essentially creating the raw data as well, for you to test and play with
// define values
dt = New Table();
// Generate summary
dt1 = dt << Summary( Group( :MyValues ), Freq( "None" ), Weight( "None" ) );
UniqueItems = dt1:MyValues << Get values;
FrequencyOfItems = dt1 << Get As Matrix;
Close(dt1,"No Save"); // Add Cumulative Frequencies back dt << New Column("CumulativeFreqCount",Numeric,Continuous); for(i = 1, i <= N Items(UniqueItems),i++, Rows = dt << Select Where(:MyValues == UniqueItems[i]) << Get Selected Rows; ValsToAppend = Transpose(Index(1,FrequencyOfItems[i])); dt[Rows,"CumulativeFreqCount"] = ValsToAppend; dt << Clear Select; );
Best
Uday
gzmorgan0
// define values
dt = New Table();
If(
	Row() == 1, 1,
	1
