fionaweston
how do I use a formula that subtracts Col B from Col A and divides by Col C but on a per month basis
I have 3 months of data in my file, Jan, Feb and Mar.
I'm using this formula
(Col Sum( :A ) - Col Sum( :B )) / Col Sum( :C )
But I need the value per month.
Thanks
ms
Super User (Alumni) ms
Re: how do I use a formula that subtracts Col B from Col A and divides by Col C but on a per month basis
Most Col Stat() functions support optional by-variables.
This formula, where :Month is the by-variable, give monthly values (repeated in every row of each month)
(Col Sum( :A, :Month ) - Col Sum( :B, :Month )) / Col Sum( :C, :Month )
ms
fionaweston
Perfect, thanks!
