I am sorry I am a clinician not a statistician. Unfortunately the place where I work does not have statistician so I have to try to figure it out myself.
I will try again
I have a retrospective data of case and control (required escalation of care or not). Outcomes of these two groups , length of stay in the hospital are significantly different when I use Fit Y by X by non-parametric Wilcoxon test. ( cases have higher Length of stay)
the two groups are not similar however and controls have severity of illness which is much higher than the case .
Since the patient whose severity of illness or higher are expected to stay in the hospital also longer, it should be expected that when I include the severity of illness in the model, the difference in length of stay between the two groups would become more significant.
However when I use the fit model using ICU length of stay as Y and the severity of illness score and categorical variable of case/control in the model effects. I get the following parameter estimates
Intercept 3.99 , prob >t < 0.0001
PIM 3 -0.17, 0.0039
Case/control -0.22 0.514
I'm assuming from this that there is no significant difference between case/control regarding length of stay while including severity of illness in the model.
