help with adding multiple columns with formula to a new table from an old table
Jun 5, 2024 02:15 PM(1734 views)
I generated multiple columns with formula and would like to find an efficient way to apply the same set of column to a new table without copying it one by one. Is there a shortcut?
If you are using JMP 16 or later, you can just copy the commands from the log that were placed there are the new columns were created and place them into the script editor and then run that JSL on the new data table.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '762681' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '762681') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '762681') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
