frank_wang
How to use two sample poisson test by JMP
Dear JMPers
Dose anyone know how to use two sample poisson test by JMP ?
Thanks a lot.
#Hypo Test
心若止水
Phil_Kay
Re: How to use two sample poisson test by JMP
It would help the JMP Community to help you if you could provide a bit more detail. I understand that you have 2 samples of Poisson-distributed data (probably counts of something). What do you want to test? A difference in the mean between the 2 samples?
It is really helpful if you can provide some example data to illustrate your question.
Regards,
Phil
I would like to know how to calculate a difference in rates between the 2 samples (2 sample poisson rate). Please include assumptions and conditions as well as hypotheses for any sample data that you can. Thanks
