RVhydrA
help creating a column that is a cumulative sum based on other columns
I am trying to create a new column in JSL that will be an ongoing sum of the previous rows in that column.  I have a column called "Total Daily Flow"  I also have a column which marks what location the data in "total daily flow came from (call that "Site"). for example,  Say on Oct. 1, (which is specified in another column called "day of water year") i have a total daily flow of 1000, and this day happens to be day 1 of the year.  I want a column whose first row will be = 1000.  then say on day two, which will be the second row in the table, Oct. 2, there is a total daily flow of 5000, I would want the new row in the new column to be 1000 + 5000 = 6000.  then say Oct. 3 has a daily flow of 3000, so the next row will be 6000+3000 = 9000.  This is to go on for every row in my table that shares the same location name (Site) and is in the same "year" as specified by the column "day of water year" (1-365).
3 ACCEPTED SOLUTIONS
Peter_Bartell
Level VIII
Re: help creating a column that is a cumulative sum based on other columns
If you are running JMP version 12, if you right click on the column header field in the data table, the New Formula Column -> Row -> Cumulative should work without having to resort to JSL. See below:
ron_horne
hi aporter​,
until someone smarter comes up with a one liner you can try my plumbers solution:
dt << New Column( "Row", formula( :Row() ), eval formula );
dt:row << delete formula;
// assuming age is time and sex is site
dt << Sort( By( :sex, :age ), Order( Ascending, Ascending ), replace table );
// now sum as you want it
dt << New Column( "sumhightbysex",
     formula( If( Row() == 1, :height, :sex == Lag( :sex, 1 ), :height + Lag( :height, 1 ), :sex != Lag( :sex, 1 ), :height, Empty() ) ), eval formula
dt:sumhightbysex << delete formula;
// sort to original order
dt << Sort( By( :Row ), Order( Ascending ), replace table );
// clean up
dt << delete column (row);
Speak( "bob's your uncle" );
mws
mws
Hi Ron,
This is a great solution, thanks for posting.
The formula for the new column sumheightbysex has a slight typo. It should be
If(Row() == 1, :height, :sex == Lag(:sex, 1), :height + Lag(:sumhightbysex, 1), :sex != Lag(:sex, 1), :height, Empty())
using the value in the new column to add to the height, and not the height from previous row,  :height + Lag(:height), 1).
G'day
Peter_Bartell
Level VIII
ron_horne
hi aporter​,
// clean up
mws
mws
Hi Ron,
G'day
ron_horne
glad you find it useful,
Perhaps the oneliner can be based on this:
Re: Syntax: How do I create an index column by ID
it would also make it independent of sorting and maintain an active formula.
but i am not sure how to tackle it.
Best
