Françoise
graphique
bonjour,
j'ai superposé 3 variables sur l'axe Y.
est-il possible d'ajouter un trait vertical pour relier le mini au maxi pour chaque identifiant de l'axe X ? Il faudrait qu'on puisse choisir la couleur, l'épaisseur et la transparence du trait vertical.
voir l'image avec un exemple dans le cercle.
Re: graphique
You could try using Range Error Bar
Or you could add Interval Bar chart and disable the "middle" value (this might require some extra calculations / columns)
And then there is of course scripting option using graphic script which is more complicated
Re: graphique
Here is one possible example for scripted option
dt << New Formula Column(Operation(Category("Aggregate"), "Minimum"), Columns(:height), Group By(:age));
dt << New Formula Column(Operation(Category("Aggregate"), "Maximum"), Columns(:height), Group By(:age));
gb = dt << Graph Builder(
	Size(525, 448),
	Show Control Panel(0),
	Variables(
		X(:age),
		Y(:height),
		Y(:"Maximum[height][age]"n, Position(1)),
		Y(:"Minimum[height][age]"n, Position(1))
	Elements(Points(X, Y(1), Y(2), Y(3), Legend(3), Summary Statistic("Mean")))
segs = Report(gb)[FrameBox(1)] << Find Segs();
ys = [];
xs = {};
For Each({seg}, segs,
	If(seg << Class Name == "MarkerSeg",
		ys = ys |/ (seg << get y values)`;
		Insert Into(xs, seg << get x values);
For Each({{ymin, ymax, x}}, Across(V Min(ys), V Max(ys), xs[1]),
	Eval(EvalExpr(
		Report(gb)[FrameBox(1)] << Add Graphics Script(
			"Back",
			Pen Color("Purple");
			Pen Size(20);
			Transparency(0.2);
			V Line(Expr(x), Expr(ymin), Expr(ymax));
Write();
This "simple" example won't work with filters.
Re: graphique
And then there is Marker Draw Expr where you can control the color and transparency from legend and width from the draw expression
View more...
	Size(746, 818),
	Variables(
		X(:age),
		Y(:height),
	Elements(
		Points(X, Y(1), Y(2), Y(3), Legend(3), Summary Statistic("Mean")),
		Points(X, Y(1), Legend(4), Summary Statistic("Mean"))
	Local Data Filter(Add Filter(columns(:age), Display(:age, N Items(6)))),
		Dispatch({}, "400", ScaleBox,
			{Legend Model(
				4,
				Properties(
					0,
					{Line Color(35), Transparency(0.2)},
					Item ID("Mean(height)", 1)
frame = Report(gb)[FrameBox(1)];
seg = (frame << FindSeg(Marker Seg(4)));
seg << Set Marker Draw Expr(
	Function({this seg, this row, x, y, size, row state},
		size = 0.1;
		Rect(
			x - size,
			:"Maximum[height][age]"n[this row],
			x + size,
			:"Minimum[height][age]"n[this row],
			1
