Mittman
getting lefthand offset between beginning of picture box and framebox from graphbuilder plot
JMP Pro 17.2
I have a plot where I want to use both overlay (to separate lines) and color (to color related lines the same way). This works great, but I lose all colors when extracting the framebox. I can keep the colors by grabbing the picturebox, but I don't know how to calculate the left offset in the plot before where the x-axis begins. It seems like I should use the y-axis width plus the y-axis label (text edit box) however the text edit box returns a width of -1.
Is there a good way to calculate the left-hand margin or (better) a way to keep all the coloring in the framebox?
// illustrate technique and problem
dt = New Table( "frame_box_ex",
	Add Rows( 48 ),
	New Column( "X",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Selected,
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8,
			1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8]
	New Column( "Y",
		Numeric,
		"Continuous",
		Set Values(
			[1.45808886692691, 2.39035819973415, 2.99796363989942, 4.0175538469545,
			4.97635791617404, 5.26099494066037, 6.35297458603344, 7.08128130389934,
			1.28206570793684, 2.65813273844257, 3.90780332034481, 5.56931861718803,
			6.5102957541246, 7.85452087528389, 8.38346720371831, 9.83684443692199,
			1.07112111561808, 1.80813159968191, 3.60012537918958, 4.59349059340839,
			6.0331086735015, 7.38976749487193, 8.09249962943829, 8.6144549883821,
			0.793139090953735, 1.29469742405061, 1.76519280701643, 2.08182485552223,
			2.78446654871733, 3.65492098470701, 4.60137160145799, 5.4641050584207,
			-0.0498633817348688, 0.867775467257285, 2.19640092615135,
			3.8415359972872, 5.73235903219136, 6.60516876928658, 7.45020127543143,
			8.66546760100397, 0.781073560404989, 1.96654139416073, 2.08763174310172,
			2.25180062442375, 3.88484451908061, 4.67635031701802, 5.77656366166124,
			6.97420411204293]
	New Column( "Unit",
		Numeric,
		"Continuous",
		Set Values(
			[1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3,
			4, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6]
	New Column( "Group",
		Numeric,
		"Nominal",
		Set Values(
			[1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
			2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2]
gb = dt << Graph Builder(
	Size( 600, 600 ),
	Variables( X( :X ), Y( :Y ), Overlay( :Unit ), Color( :Group ) ),
	Elements( Line( X, Y, Legend( 14 ) ) ),
		Dispatch(
			"X",
			ScaleBox,
			{Min( 0 ), Max( 8 ), Inc( 1 ), Minor Ticks( 0 )}
nw = New Window( "for testing",
	Outline Box( "complicated plot",
		Spacer Box( Size( 2, 10 ) ),
		lu1 = Lineup Box( N Col( 3 ), Spacing( 0 ) )
lu1 << Append( Report( gb )[AxisBox( 2 )] );
lu1 << Append( Report( gb )[FrameBox( 1 )] );
lu1 << Append( Report( gb )[LegendBox( 1 )] );
//end of row
lu1 << Append( Spacer Box() );
lu1 << Append( Report( gb )[AxisBox( 1 )] );
//end of row
lu1 << Append( insrt_icons = H List Box() );
numXAxisWidth = (gb << report)[AxisBox( 1 )] << get width;
numSteps = N Items( Associative Array( Column( dt, "X" ) ) << get keys );
numOneIncr = (numXAxisWidth) / (numSteps);
For( _i = 1, _i <= numSteps, _i++,
	insrt_icons << Append( Spacer Box( Size( numOneIncr, numOneIncr ), Color( _i ) ) )
Re: getting lefthand offset between beginning of picture box and framebox from graphbuilder plot
Interesting approach! If you can keep everything inside the frame box, it will be easier...just use with the graph's coordinate system. I suspect you are going to be fighting with the integer coordinate system for the displayboxes as well as trying to find the proper origins; you also will disconnect the graph from the axes (dragging the scales, etc won't work.)
	Add Rows( 48 ),
	New Column( "X",
		Numeric,
		"Continuous",
		Set Selected,
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6,
			7, 8]
	New Column( "Y",
		Numeric,
		"Continuous",
		Set Values(
			[1.45808886692691, 2.39035819973415, 2.99796363989942, 4.0175538469545, 4.97635791617404, 5.26099494066037, 6.35297458603344,
			7.08128130389934, 1.28206570793684, 2.65813273844257, 3.90780332034481, 5.56931861718803, 6.5102957541246, 7.85452087528389,
			8.38346720371831, 9.83684443692199, 1.07112111561808, 1.80813159968191, 3.60012537918958, 4.59349059340839, 6.0331086735015,
			7.38976749487193, 8.09249962943829, 8.6144549883821, 0.793139090953735, 1.29469742405061, 1.76519280701643, 2.08182485552223,
			2.78446654871733, 3.65492098470701, 4.60137160145799, 5.4641050584207, -0.0498633817348688, 0.867775467257285, 2.19640092615135,
			3.8415359972872, 5.73235903219136, 6.60516876928658, 7.45020127543143, 8.66546760100397, 0.781073560404989, 1.96654139416073,
			2.08763174310172, 2.25180062442375, 3.88484451908061, 4.67635031701802, 5.77656366166124, 6.97420411204293]
	New Column( "Unit",
		Numeric,
		"Continuous",
		Set Values(
			[1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6,
			6, 6]
		Numeric,
		"Nominal",
		Set Values(
			[1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
			2, 2]
	Size( 600, 600 ),
		Dispatch( {}, "X", ScaleBox, {Min( 0 ), Max( 9 ), Inc( 1 ), Minor Ticks( 0 )} ),
		Dispatch( {}, "Y", ScaleBox, {Min( -1 ), Max( 10.1 ), Inc( 2 ), Minor Ticks( 0 )} )
Report( gb )[framebox( 1 )] << addgraphicsscript(
	Text( {1, 8}, JMP Version() );
	For( here:x = 1, here:x < 8, here:x += 1,
		Fill Color( HLS Color( here:x / 9, .5, 1 ) );
		Rect( here:x, -.2, here:x + 1, -.8, 1 );
		Fill Color( "white" );
		Circle( {x + .5, -.5}, .25, "FILL" );
		Text Color( "black" );
		Text Size( 12 );
		Text( center justified, {x + .5, -.65 /*vertical centering depends on text size*/}, Substr( "ABCDEFG", x, 1 ) );
Add a graphics script to the framebox to make custom displays.Add a graphics script to the framebox to make custom displays.
	Add Rows( 48 ),
	New Column( "X",
		Numeric,
		"Continuous",
		Set Selected,
		Set Values(
			7, 8]
	New Column( "Y",
		Numeric,
		"Continuous",
		Set Values(
	New Column( "Unit",
		Numeric,
		"Continuous",
		Set Values(
			6, 6]
		Numeric,
		"Nominal",
		Set Values(
			2, 2]
	Size( 600, 600 ),
		Text Size( 12 );
