aadecarlojr
formula to provide greatest numerical value from multiple columns
I have two related columns with numerical values and I cannot figure out how to create a formula column that delivers the maximal value of the two input columns. Everything I try ends up with an "else" in the formula and I don't think I want that.
thanks if you know how.
Dr. DeCarlo
Jeff_Perkinson
Re: formula to provide greatest numerical value from multiple columns
It's not clear exactly what you want, @aadecarlojr.
If you want the maximum value across all the values of the two given columns then the JSL that @txnelson gave above will work.
If, on the other hand, you want something like this:
A
B
Max of A and B
1
2
2
4
3
4
8
7
8
Then the formula:
Maximum(:A, :B)
will give you that.
-Jeff
max( col max(:col1), col max(:col) );
I think this will give you the maximum value for the 2 columns
Jeff_Perkinson
A
B
Max of A and B
1
2
2
4
3
4
8
7
8
Then the formula:
Maximum(:A, :B)
will give you that.
-Jeff
aadecarlojr
Thanks to Jeff and TxNelson. I did want the latter, row by row maximum of two columns and that works.  In my research we entered separate R and L data but also want a column variable that contains the max from either R or L.
Love solutions!
