ron_horne
finding the mode
hi everyone,
i would like to produce a table summery that gives the mode of a variable for each category of another variable.
ideally, this would work:
dt = open ("$SAMPLE_DATA/Mail Messages.jmp");
dt << summary ( Group ( :From ), Mode (:To) );
alternatively, i would stack the table by "From" and calculate the mode at each row. yet, "Mode" is not an option in Table summary or column formula.
any ideas calculating the mode are welcome including in sending to SAS.
i am using JMP 10.
thank you,
Ron
11 REPLIES 11
Re: finding the mode
I believe that this will also produce the intended result:
dt = open ("$SAMPLE_DATA\Cars.jmp");
dt2 = dt << summary(group(:Make, :R Leg));
dt2 << selectwhere(colmaximum(:n rows, :make) != :n rows) << Delete Rows;
Cheers,
Brady
ron_horne
Thank you Brady,
This is by far the most parsimonious and robust script.
I would like to add one optional line of code to disable the possibility of missing values as the mode:
// option to disable the possibility of missing values as modes
dt2 << Select Where ( IsMissing (:R Leg)) << Delete Rows;
