bwanders
Exponential Curve Fitting
Look at my attached file.  I have fitted an Exponential 3P curve to data that is based on %.  I have added a range check as well as a response limit for my "% knockdown" column.  I would like to have my fit curve parameter estimates not exceed 100%.  Is there a way to do this?
mpb
mpb
Re: Exponential Curve Fitting
Instead of using the Fit Curve personality of Nonlinear, you can use the Custom Model personality (Help Index: Nonlinear Platform, Custom Models).
1. Create a column formula (say in column MyFormula) with parameters a, b and c:  a + b*exp(c*Time)
2. In the initial Nonlinear dialog Put MyFormula in the X, Predictor Formula box and %Knock Down in the Y, Response box. Then click OK.
3. In the second Nonlinear dialog you can click the red triangle by Nonlinear Fit and choose the first item, Parameter Bounds. You will then have the opportunity to supply Lower and/or Upper bounds for each of a, b, and c.
mpb
mpb
bwanders
Thank you.  This nonlinear custom model definitley brought me to a new place in JMP.
