    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
yvesprairie
extracting the directory of a jmp file in JSL
Hi all,
I have managed to do what I want in a convoluted way (using word and character manipulations)  but I feel there must be an easier way to do this. All I want is to extract the directory of a file I just selected using the Pick File function in JSL so that the next time, it starts from that directory. Any suggestions??
Thanks, Yves
Re: extracting the directory of a jmp file in JSL
Take a look at my script below, and tell me if I am getting closer to what you want.
theDirectory = "";
xx = Pick File( "Pick a File", theDirectory );
theDirectory = Substr( xx, 1, Length( xx ) - Length( Word( -1, xx, "\/" ) ) - 1 );
// now this Pick File will go to the directory that the file from the last
// Pick File was selected from
yy = Pick File( "Pick a File", theDirectory );
// If you want this Pick File to span across different scripts, then it would be a simple
// matter to save the directory in a specific namespace and get the
// directory location from a variable saved in that namespace.
// If you want to have the Pick File directory available from JMP session to JMP session
// then what I have used in the past, is to simply save the character string for the
// directory to a .txt file, using Save Text File() and Load Text File() to make the directory
// persistant
Check out the Files in Directory() function in the Scripting Index
yvesprairie
Sorry I pressed the wrong button!!! Unfortunately, this is not a solution @txnelson . This only lists the files of a known directory. I want to browse to find the file I want and once I have chosen it, I want to save the directory so that next time I want to browse , it starts at that previous directory.
Cheers, Yves
theDirectory = "";
// persistant
yvesprairie
Yes this works great! It is close (but better) than what I had come up with. I just thought there should be a built-in function to extract the location (the directory path) of a file. Many thanks @txnelson !
Regards, Yves
