LaserGuy
expr and evalexpr for Graph Builder gradient limits
I am trying to set up a script that will generate a Graph Builder with gradient min and max equal to to Quantile values of the Column being plotted.
Unfortunately, the expr and evalexpr syntax I am using doesn't work for the matrix in "Scale Values".
I need help.
dt0 = current data table();
param = "Voltage";
colp = dt0:param;
graph_high = Quantile( 0.975, column(dt0, param) << get as matrix() );
graph_low = Quantile( 0.025, column(dt0, param) << get as matrix() );
cmd = expr(
	Graph Builder(
		Size( 550, 550 ),
		Variables(
			X( :x ),
			Y( :y ),
			Color( :expr(param) )
		Elements( Points( X, Y, Legend( 6 ) ) ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					6,
					Properties(
						0,
						{gradient( {Scale Values( [expr(graph_low) expr(graph_high)] )} )}, // *Need Help Here*
						Item ID( expr(param), 1 )
eval(evalexpr(cmd));
ErraticAttack
Re: expr and evalexpr for Graph Builder gradient limits
I don't have your data to validate, but this should work:
param = "Voltage";
colp = dt0:param;
val matrix = [](1,0) || graph_low || graph_high;
cmd = expr(
	Graph Builder(
		Size( 550, 550 ),
		Variables(
			X( :x ),
			Y( :y ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					6,
					Properties(
						0,
						{gradient( {Scale Values( Expr( val matrix ) )} )}, // *Need Help Here*
Jordan
ErraticAttack
param = "Voltage";
colp = dt0:param;
cmd = expr(
	Graph Builder(
		Size( 550, 550 ),
		Variables(
			X( :x ),
			Y( :y ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					6,
					Properties(
						0,
Jordan
LaserGuy
Thanks a lot. This worked.
Now that you gave me the idea of creating a matrix using variables, and then putting that matrix into the Graph Builder script, I decided to play around. It looks like I don't need to use Expr() around the "val matrix".
I find that this works as well:
param = "Voltage";
colp = dt0:param;
val matrix = matrix( {graph_low, graph_high} );
cmd = expr(
	Graph Builder(
		Size( 550, 550 ),
		Variables(
			X( :x ),
			Y( :y ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model(
					6,
					Properties(
						0,
						{gradient( {Scale Values( val matrix )} )},
