LT
LT
export plots to PPT with the same scale and resolution
I want to JSL to generate report (.ppt).
There are 2 plots I want to export: 5 groups and 3 groups.
I want each group with 250*250, so 5 groups plot should be 1250*250 and 3 groups plot should be 750*250.
I use Save Presentation to export plots.
5 groups size is the same as I export plots manually but 3 groups size is not. The 3 groups size is squeezed, only 75%.
How could I export multiple plots with the same scale and resolution?
NonLeakage_graph = dt << Graph Builder(
	Size( 1250, 250 ),
	Variables( X( :Lot ), Y( :drift% ), Group X( :Label ), Color( :Lot ) ),
	Elements( Box Plot( X, Y, Legend( 1 ) ) ),
	By( :Rel_Test ),
		Dispatch( {}, "drift%", ScaleBox,
			{Format( "Percent", 12, 0 ), Min( -0.25 ), Max( 0.25 ), Inc( 0.05 ),
			 Minor Ticks( 0 ), Add Ref Line( 0.2, "Solid", "Red", "20%", 1 ),
			 Add Ref Line( -0.2, "Solid", "Red", "-20%", 1 )}
NonLeakage = NonLeakage_graph << Report;
save_path = "D:\Reliability Qual\reliability report template\jmp_example.pptx";
For( i = 1, i <= N Items( NonLeakage ), i++,
	If( File Exists( save_path ),
		NonLeakage[i] << Save Presentation( save_path, Append );
		NonLeakage[i] << Save Presentation( save_path );
NonLeakage << Close Window;
dt << Clear Row States;
dt << Select Where( (Contains( {"0cyc", "0hrs"}, :ReadPoint )) | (!Contains( {"IGSS", "IGSSR", "IDSS"}, :Label )) );
dt << Hide( 1 ) << Exclude( 1 );
dt << Clear Selection;
dt << Select Where( (!Contains( {"0cyc", "0hrs"}, :ReadPoint )) & (Contains( {"IGSS", "IGSSR", "IDSS"}, :Label )) );
Summarize( dt, l_groups = By( :Rel_Test ) );
Leakage_graph=dt << Graph Builder(
	SendToByGroup( {:Rel_Test == "H3TRB"} ),
	Size( 750, 250 ),
	By( :Rel_Test ),
				{Format( "Fixed Dec", 12, 0 ), Min( 0 ), Max( 20 ), Inc( 5 ),
				Minor Ticks( 0 ), Add Ref Line( 10, "Solid", "Red", "10", 1 )}
Leakage = Leakage_graph << Report;
Leakage << Save Presentation( "D:\Reliability Qual\reliability report template\jmp_example.pptx",append );
hogi
Level XIII
Re: export plots to PPT with the same scale and resolution
the issue:
how to control the Size of the FrameBox ?
https://community.jmp.com/t5/Discussions/Graph-builder-Frame-size-JSL/m-p/702694/highlight/true#M887...
there is a wish:
Functionality to generate Plots with specific Plot Size
The # of Kudos indicates a strong demand to fix the issue.
LT
LT
Hi hogi,
This does not work. Everything looks good in JMP but after exporting to PPT, the plots' scales are different.
hogi
Level XIII
Hi @LT ,
You seem to be right. However, the issue is not where I thought it was.
With the hints in the first link, you can achieve a lot — even more than I thought possible when I wrote my first reply.
This code creates plots with the requested proportions:
Three frames with 250x250 -> 750x250
and five frames with 250x250 -> 1250x250.
When you copy the graphs to the clipboard and paste them into a graphics program, you can see that all the subplots are the same size.
The code also points to the actual problem:
regardless of the size of the PNG or JPG image, it can be scaled in the presentation according to some hidden rules.
I fear that the << save presentation function doesn't allow the user to adjust these rules.
A workaround: You can use scripting (e.g. via the Python interface in JMP) to specify the size and position of the inserted graphs in the presentation.
Alternatively, you can email [email protected]  for further suggestions.
Perhaps there is a hidden setting in << save presentation ...
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
 fn = "$TEMP/jmp_example.pptx"
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Presentation(fn );
For each( {selection}, {{13, 14, 15}, {13, 14, 15, 16, 17}},
	Eval(
		Eval Expr(
			gb = Graph Builder(
				Fit to Window( "Off" ),
				Variables(
					X( :height ),
					Y( :weight ),
					Group X( :age ),
					Overlay( :age )
				Elements(
					Points( X, Y ),
					Smoother( X, Y )
				Local Data Filter(
					Conditional,
					Add Filter(
						columns( :age ),
						Where( :age == Expr( selection ) )
	fb = Report( gb )[FrameBox( 1 )];
	fb << Frame size( 250, 250 );
// show(fb << get size);
	gb << save presentation( fn, Append );
Web( fn );
