entering the last value of a list
I'm attempting to get the last value from a list that was created using the following:
x = :Values << get values;
I tried using x[n rows()] since I know that works with the get as matrix() function, but the list is nominal and I keep getting an error.
Any help is appreciated. I'm using JMP 11
pmroz
Re: entering the last value of a list
x[nrows(x)];
That should do it.
hlrauch
If the data type of the Values column is "Character" (and therefore the modeling type of the Values column is either nominal or ordinal), then x is a list instead of a matrix. (Values in a list is enclosed in curly braces {} instead of brackets [] ). In that case try using the N Items() function instead of the N Rows() function.
lastitem = x[N Items( x )];
pmroz
x[nrows(x)];
That should do it.
hlrauch
works great. Thanks
