NetflixCrow956
enlarge the graph in the powerpoint
Hello everyone, I have a problem that I can't solve. In my script, the size of the graph does not correspond to the size of the graph in Powerpoint, even if I change the values.
If someone has the answer I would be delighted and thank you.
Phil_Kay
Re: enlarge the graph in the powerpoint
Just to confirm, you are using the save as PowerPoint capability.
You might want to explore the graphics file format options.
I think the default and recommended format is EMF, which enables you to resize the graphic in PowerPoint without loss of quality.
However, when I save as PNG it seems to be more faithful to the size of the original image.
I hope this helps.
Phil
