Sebastienlg
empirical quantiles
Hello all,
Is there a way to recover the empirical quantiles (Example quantile at 99.865% and 0.135%) in the case that the data does not follow a normal distribution?
I cannot find it on JMP...
Thanks a lots for your answer,
Sebastien
Re: empirical quantiles
See Help > Scripting Index > Functions > Quantiles:
Sebastienlg
Thanks for you reply.
How do you apply the quantile function to a to JMP column from a dataset?
I have some difficulties to do that...
Sebastien
There may be a better way( see Mark's answer above) , or a more correct way to estimate the values you want.  All I am doing is interpolating the value from the known percentiles above and below.
Here is an example of finding 99.865 when the 90th and 100th percentiles are known.
p90 = 68;
p100 = 70;
p99865 = (99.865 - 90) / (100 - 90) * (p100 - p90) + p90;
