Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
I am a basic user. So far, I do not use scripts but only menus.
I have generated more that 50 distributions curves and statistics with few clicks using the "analysys/distribution" menu.
I would like now to take the results of those distribution analysis (such as simple things like average,, standard deviation etc...) to a new table in order to process them again.
In the report window, right click on e.g. the table "Summary Statistics" and select "make into data table" or "make combined data table". The latter brings all similar table boxes into a single data table. Very convenient if you have all the histograms in the same report. If each histogram resides in it's own window you can collect them in a journal (ctrl-J) first and then click "make combined data table".
You may want to try the Tabulate Platform. It can calculate: N, Mean, Stdev, Min, Max, Range, % of Total, Median, Quantiles, etc. After you have it setup the way you want it, you can convert it to a data table with the red diamond.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '6354' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '6354') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '6354') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
