    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
warnost
Count the number of zeroes in a column (JSL)
I have been using the Distribution platform to manually analyze a data set, but since I will have to repeat I am now trying to create a JSL script to extract the measures that are most important. The data looks like this:
Model          Score
MODEL1     3.54485
MODEL2     2.36485
MODEL1     5.38456
MODEL2     2.14556
MODEL1     0
MODEL2     0.04856
I would like to extract the mean, std dev, etc. but also I would like to know how often the score is zero for each model. I have tried using summary, tabulate, and a few functions in JSL. I can accomplish everything but the "count zeroes" portion. I can get this number manually by creating the distribution and then doing histogram options >> show counts. Any ideas on how to do it in JSL? Code so far:
dt = Open("C:\Desktop\Results.jmp);
dt << Summary(
  Group( :Model ),
  Median( :score ),
  Mean( :score ),
  Std Dev( :score ),
  Range( :score ),
ms
Super User (Alumni) ms
Re: Count the number of zeroes in a column (JSL)
Here is a sligtly simplified version that should give the same result.
dt = Open( "C:\Desktop\results1" || filename || ".jmp" );
dt2 = dt << Summary( Group( :Model ), Median( :score ), Mean( :score ), Range( :score ) );
dt2 << Delete Rows( 2 ) << New Column( "Num Zeroes",
  Numeric,
  Continuous,
  Format( best ),
  <<set each value( N Rows( dt << get rows where( :score == 0 & :Model == "Model1" ) ) )
You can use the summary command and see the counts by grouping on score:
Data Table("Untitled") << Summary(Group(:Score))
or in jsl you could do:
zero_count = 0;
for each row(
    if(:score == 0, zero_count++)
show(zero_count);
warnost
Thank you! I am sure the code below is less than optimal, but I was able to incorporate your code to get the result I wanted.
filename = ""; /*general name so I can repeat for different files*/
dt = Open("C:\Desktop\results1" || filename || ".jmp");
zero_count = 0;
for each row(
    if(:score == 0 & :Model == "Model1", zero_count++)
dt << Summary(
  Group( :Model ),
  Median( :score ),
  Mean( :score ),
  Range( :score ),
dt2 = Data Table( "results1" || filename || " By (Model)" );
dt2 << Delete Rows(2); /*I only want Model1 */
dt2 << New Column( "Num Zeroes",
  Numeric,
  Continuous,
  Format( best),
  <<set each value( zero_count ),
ms
  Numeric,
  Continuous,
  Format( best ),
warnost
Thank you! This is much cleaner.
