Leo_Huang
data filter for several graph from a same data table
I want to plot several graphs with the same data source in a same window.Here I put a data filter before the plotting.But it dosen't work.Could anyone help??!
dt= Open( "$SAMPLE_DATA/Big Class.jmp" );
New Windows("mt report",
  nwBB = Border box(
 dt<< Data Filter(
   Add Filter( columns( :group ), Where( :group == 1 ) )
V List Box(
Graph Builder(.....);
Re: data filter for several graph from a same data table
See the script below for the proper ordering of the elements to make the script work
New Window( "mt report",
	nwBB = Border Box(
		V List Box(
			dt << Data Filter( Add Filter( columns( :group ), Where( :group == 1 ) ) ),
			dt << Graph Builder(
				Size( 528, 454 ),
				Variables( X( :weight ), Y( :height ) ),
				Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
				Size( 528, 454 ),
				Variables( X( :height ), Y( :weight ) ),
pmroz
Try something like this:
dt = open("$sample_data\Big Class.jmp");
nw = new window("Test 2 Graphs + Data Filter",
	vlistbox(
			Size( 518, 445 ),
			Variables( X( :age ), Y( :sex ), Overlay( :sex ) ),
			Elements( Points( X, Y, Legend( 9 ) ) ),
			Local Data Filter( Add Filter( columns( :height ) ) )
			Size( 526, 451 ),
			Elements( Points( X, Y, Legend( 5 ) ), Smoother( X, Y, Legend( 6 ) ) ),
			Local Data Filter( Add Filter( columns( :sex ) ) )
Leo_Huang
So if I want to get the plot with column(group) value=1,I have to code like this??
Elements(...)
Local Data Filter(Add Filter( columns( :group ), Where( :group == 1 ) ))),
	nwBB = Border Box(
		V List Box(
				Size( 528, 454 ),
				Size( 528, 454 ),
Leo_Huang
Big thx!! I'll try it tomorrow in company!
Sburel
It seems that in JMP16, this script would not have the data filter included in the report (as was the case for JMP15) but rather in its own data filter window.
Any suggestions to get a result similar to JMP 15?
Best,
Sebastien
