Blanco15
creating new variables derived from multiple rows per ID
Hello ,
I am trying to create one variable (type2) from multiple rows per ID using variable type. I want to covert a table like this one:
ID
type
1
A
1
A
1
B
2
A
2
A
3
B
3
B
3
B
To:
ID
type2
1
C
2
A
3
B
Where type2 is:
If type is always A then type2=A;
If type is always B then type2=B;
If type is a combination of A and B then type2=C;
Thanks
Re: creating new variables derived from multiple rows per ID
Many ways to do this. I would calculate how many times type appears in ID and if it is the same amount as ID appears in data, then you know it is the only type.
Summary with formula:
dt = New Table("From",
	Add Rows(8),
	New Column("ID", Numeric, "Nominal", Format("Best", 12), Set Values([1, 1, 1, 2, 2, 3, 3, 3])),
	New Column("type", Character(16), "Nominal", Set Values({"A", "A", "B", "A", "A", "B", "B", "B"}))
dt_summary = dt << Summary(
	Output table("To"),
	Group(:ID),
	N(:type),
	Subgroup(:type),
	Freq("None"),
	Weight("None"),
	statistics column name format("column"),
	Link to original data table(0)
dt_summary << New Column("type2", Character, "Nominal",
	<< Set Each Value(
		If(:"type, A"n == 0, "B",
			:"type, B"n	== 0, "A",
			"C"
And other using Col Sum with Select duplicated rows:
	Add Rows(8),
dt << New Column("type2", Character, Nomimal, Formula(
	If(Col Sum(1, :ID) == Col Sum(1, :ID, :type),
		:type,
		"C"
wait(1);
dt:type2 << Delete Formula;
wait(1);
dt << Select Duplicate Rows(Match(:ID, :type2));
wait(1);
dt << Delete Rows;
See Scripting Index for more information about the functions especially Col Sum.
It looks like your table may be sorted by :ID and :type. If it is, or if you are willing to sort it, you can take advantage of this and use a (relatively) simple formula for the :type2 column:
If( :type[Col Min( Row(), :ID )] == :type[Col Max( Row(), :ID )],
	:type,
	"C"
Cheers,
Brady
