hariharan249
Error while using Azure MFA to connect with JMP
I have rightly set up the ODBC connection version 17 for SQL server using Azure MFA. However, when I try to connect for the DSN via JMP i get the following error. how to overcome this error in JMP14.
[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Password option must not be specified, if Authentication option is 'ActiveDirectoryInteractive'.
0 REPLIES 0
