creating new columns with a for loop with column names and formula
I am trying to create a split table from an existing table and add new columns into the split tables each with a formula based on the columns that were split. However the code creates the new columns but gives me "Formula evaluation errors"
dt2 = Current Data Table();
// Create the split data table
dt2 = dt << Split(
	Split By( :S ),
	Split(
				:Name( "Median(data)" )
	Group( :L, :m, :C, :P, :z, :x ),
	Remaining Columns( Drop All ),
	Sort by Column Property
colname = {"B","C"};
colby = {"A","B"};
// Add new columns to the split data table
For( i = 1, i <= N Items( colname ), i++,
dt2 << New Column( colname[i]||"/"||colby[i],
	Numeric,
	"Continuous",
	Format( "Best", 12 ),
	Formula( column(colname[i]) / column(colby[i]) )
Re: creating new columns with a for loop with column names and formula
Try changing the Column() function to As Column() function
JMP formula definition will not evaluate when being defined, only when run.  Therefore, the formula needs to be presented to JMP in a fully defined form.
Column( colname[i] ) /  Column( colby[i] )
needs to presented to JMP as
Column( "B" ) / Column( "A" )
Using the Substitute function allows for the expanding of the code as required
	Eval(
		Substitute(
				Expr(
					dt2 << New Column( colname[i] || "/" || colby[i],
						Numeric,
						"Continuous",
						Formula( Column( __colname__ ) / Column( __colby__ ) )
			Expr( __colname__ ), colname[i],
			Expr( __colby__ ), colby[i]
I am still getting the same error, as below
Column B/A Formula Interrupted
Cannot convert argument to a number [or matrix] 1 times At rows: 2 Operation: Divide, Column( "B" ) /  /*###*/Column( "A" ) /*###*/
Formula evaluation errors have been ignored
Column C/B Formula Interrupted
Cannot convert argument to a number [or matrix] 1 times At rows: 2 Operation: Divide, Column( "C" ) /  /*###*/Column( "B" ) /*###*/
That worked, thanks!
