agat
courbe roc / roc curve
bonjour, je ne parviens pas à réaliser de courbe Roc avec jump 18, pouvez vous m'indiquer comment procéder ? / Hello, I can't make a Roc curve with jump 18, can you tell me how to proceed?
Re: courbe roc / roc curve
Welcome to the Community.
In JMP, go to:
     Help=>Search JMP
In the Search dialog window that pops up, enter
     roc
It will provide you with several options
In JMP, go to:
     Help=>Search JMP
     roc
