kevinwtbolger
How to dynamically reference the y-axis of a scale box in Graph Builder using JSL
Or anywhere for that matter.
I'm writing a function that generates some specialist graphs for work. Im doing some extra drawing on the canvas and need the graph to re-adjust on the y-axis to fit everything in. I can achieve this by getting the max and min of every point I am plotting and setting those (+/- 5%) as my upper and lower limits. However, in order for the changes to take effect I need to call the axis label. I've tried index numbers. I've tried storing the name as a variable and calling the variable. None of my attempts seem to work and the documentation is not comprehensive on this topic.
Example:
Within the graph builder and send to report I have:
Dispatch({},
"The Axis Name",
ScaleBox,
{Format( "Fixed Dec", 15, 0 ), Min( llim ), Max( ulim ),
Inc( 1 ), Minor Ticks( 1 )}
To get this to work in a function, I currently have to hard code the name. I would like for it to update dynamically no matter what graph I am plotting.
Something to the effect of
Dispatch({},
Y-Axis,
ScaleBox,
Is what I am looking for.
Re: How to dynamically reference the y-axis of a scale box in Graph Builder using JSL
You pose an interesting question regarding axis identification in Graph Builder.  I have taken a look at the axis structure that Graph Builder uses, and it appears to have an organization to it, that one can use.
The above Graph Builder chart has one Y axis and several X axes.  The structure for the graphs I tried out always used Axis 1 as the first X axis and Axis 2 and the first Y axis.  So in using the below code, even when the graph type was changed, the axis number remained the same.
Names Default to Here(1);
dt=open("$SAMPLE_DATA/semiconductor capability.jmp");
gb=Graph Builder(
                Size( 593, 526 ),
                Show Control Panel( 0 ),
                Variables( X( :PNP1 ), Y( :NPN1 ), Group X( :SITE ) ),
                Elements( Points( X, Y, Legend( 5 ) ), Smoother( X, Y, Legend( 6 ) ) )
report(gb)[Axis Box(1)] << min(150);
Axis Box(2) reference would change the Y axis.
There are also Axis boxes 3,4,5 & 6, which are the other 5 X axes being displayed.
This example has added in a second variable to the Y axis, however, the Axis Box(1) is still the first X axis, Axis Box(2) is the Y axis for the top column, "PNP4", while Axis Box(3) is the Y axis for the "NPN1" column.
GB=Graph Builder(
                Size( 593, 526 ),
                Variables( X( :PNP1 ), Y( :PNP4 ), Y( :NPN1 ), Group X( :SITE ) ));
If you rt mouse click on the Grey Expansion Triangle and select
     Edit==>Show Tree Structure
you should be able to determine the axis box structure for the graphs that you are using, and will be able to programmatically determine how to reference the correct Axis Box
gb=Graph Builder(
                Size( 593, 526 ),
GB=Graph Builder(
                Size( 593, 526 ),
kevinwtbolger
This perfectly solved my problem. Thanks Jim. My function is still a work in progress re: making it generic enough to share but once I figure it out but I will post here on the JMP community once I have made it generic enough.
For anyone wondering, I believe my issue is I was trying to reference the report within the report, before it was fully generated (though I may be wrong there).
As a follow-on to Jim's example, you can use XPath() to obtain a list of all the AxisBoxes in the report.  Then, you can loop through the list making the desired changes as appropriate.  The following demonstrates XPath() and then simply selects each axis in a For loop.
/* Obtain a list of al the AxisBoxes in the report */
gbAxis = Report( gb ) << XPath( "//AxisBox" );
/* Loop through each to see which axis each references */
For( i = 1, i <= N Items( gbAxis ), i++,
    gbAxis[i] << Select;
       Wait( 1 );
I hope this helps!
Wendy
Wendy
hogi
Level XIII
After having access to the individual axis objects, the next task is to find out which axis belongs to which "axis".
Is the first axis the x or the y axis.
And how about other plot types? Does the same logic hold for Graph Builder Boxes and Graph Boxes?
Please have a look at this wish:
Make it easier to get results from reports via JSL
Besides getting results from the report, one could also simplify the way of adjusting a report.
The Dispatch command is well equipped -- one can directly use information like "X title" to control where the message is sent to:
SendToReport( Dispatch( {}, "X title", TextEditBox, {Set Text( "xxx" )} ) )
For Xpath, this doesn't seem to be possible yet ...
