mvanderaa1
copy graph from analysis platforms does not include the legend
I have noticed that when I copy a graph from any analysis platform it does not include the legend.
Example: Run the "Reliability Growth" script in this sample data table
Names Default to here(1);
Open("$SAMPLE_DATA/Reliability/Concurrent Systems.jmp");
A "copy graph" action of the Crow AMSAA plot yields the graph without any legend. For me, the legend adds vital information in most cases so I have to resort to a manual window snip or cropping to get the graph to use in external programs. Is there a way to copy the legend along with the graph?
JMP output
Desired output
Re: copy graph from analysis platforms does not include the legend
One option is to use Selection tool first (press S or select it from toolbars)
and then select a bit more than just the graph and right click to copy
This might also be worth of checking out if you have timeGetting high-quality graphics out of JMP
mvanderaa1
Alright that's easy enough, thanks!
