tom_abramov
Level V
converting a date from a string into a JMP date : AM/PM vs 24hr time problems
I'm having trouble converting values like
08:49:46 PM
10:30:46 AM
from Character Column to Numeric h:m:s 24h format.
I would like to run the conversion without JSL and without depending on Operation system time format.
Please assist.
Regards,
Tom.
gzmorgan0
Re: converting a date from a string into a JMP date : AM/PM vs 24hr time problems
Change your format to Duration, or  Format( "hr:m:s", 13, 0 ).  Note the other format with AM and PM is Format("h:m:s",13,0)
