UberBock
Selection and coloring cells
So if I use:
dt = currentDataTable();
dt << select where(:RESULTNAME != "Success");
dt:RESULTNAME << color cells(RGB Color( 255, 150, 150 ));
dt << clear select();
When the data table has only 'Success' all cells are colored.  If the table has 1 value that is not 'Success' then it colors that cell and only that cell.  Anyway to have it not color all the cells when it only has 'Success'
Re: Selection and coloring cells
Try using this method
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dt<<select where(:age==12);
dt:age<<color cells("red", dt<<get selected rows);
UberBock
Thanks again!
pmroz
You can also use get rows where:
match_rows = dt << get rows where(:RESULTNAME != "Success");
dt:RESULTNAME << color cells(RGB Color( 255, 150, 150 ), match_rows);
