vishwasanj
concatenate data tables on the go
Hi All,
This may be starighfroward but I am not able to get the right JSL commands.
I really appreciate if anyone could help me.
I am running a FOR loop and every time I run it, I open a data table.
I want to concatenate all data tables together and save it as FINAL TABLE.
Thanks.
uday_guntupalli
Level VIII
Re: concatenate data tables on the go
@vishwasanj :
 Please use the following code to fix your problem .
n = 5 ; // Random # of iterations
for (i = 1 , i <= n , i++,
	  RowsToSelect = Random Index(40,5);
	  dt << Select Rows(RowsToSelect);
	  dt << Subset("");
// In your case data is coming from a file
// So I am closing out the source table here that I opened for the purpose of demonstration
Close(dt,"No Save");
// Make a list of all open Data tables
openDTs = List();
For( i = 1, i <= N Table(), i++,
	Insert Into( openDTs, Data Table( i ) );
// Concatenate
for(i = 1 ,i <= N Table(), i++,
		dt_Results = openDTs[i];
		//Close(openDTs[i]);
		dt_Results << Concatenate(openDTs[i],"Append To First Table");
		Close(openDTs[i]);
dt_Results << Set Name("Results");
Best
Uday
uday_guntupalli
Level VIII
@vishwasanj :
  Hello . I think this can be done through the following piece of code .
	  dt1 = dt << Subset("");
	  If(i == 1,
			dt_Results = dt1 ;
			dt_Results << Concatenate(dt1,"Append To First Table");
			Close(dt1,"No Save");
Best
Uday
uday_guntupalli
Level VIII
Just to explain what is going on here :
- Once you open the loop - we are randomly choosing which rows to select to generate a sample set - here
dt << Select Rows(RowsToSelect); dt1 = dt << Subset("");
- At i = 1 , you are initializing the format of the output data table that defines your results
- When i != 1 , you are concatenating data from the newly formed table back to the template file
Best
uday
Best
Uday
vishwasanj
Thank you Uday. I think I get an idea of how to do it. But what I have is, I run the loop and it creates a new data table every time it completes. I don't have a control on the count or choice of the file, because it is created automatically. I could have 2, or 5, or 9 data tables at the end of the loop opened. I wanted to concatenate all into one table.
I hope I didn't over-complicate it. Let me know your thoughts. I will see how I can modify your script. Thank you so much.
uday_guntupalli
Level VIII
@vishwasanj :
	  dt << Subset("");
openDTs = List();
// Concatenate
		Close(openDTs[i]);
Best
Uday
