cdoraem
error: row number (-1) is not valid.
I am following the very first example on "hello world' in JMP scripting basic and has encountered error.
script:
for(i=1, i<5, i++,
X=i;
A="Hello, World";
print(X,A));
print("done");
error:
Cannot set value for the column 'X' because the row number (-1) is not valid.
Can anyone enlighten what is wrong with the script?
uday_guntupalli
Level VIII
Re: error: row number (-1) is not valid.
The issue is one of scoping.  JMP is finding your variable 'X: in a data table.....I assume.  And because of that, it is wanting to have a subscript for the X variable.  To make this work and point to the memory variable "X" you need to force the proper reference to it by placing "::" in front of the variable.
For( i = 1, i < 5, i++,
	::X = i;
	A = "Hello, World";
	Print( ::X, A );
Print( "done" );
uday_guntupalli
Level VIII
Best
Uday
uday_guntupalli
Level VIII
Seems to run fine ..
Best
Uday
	::X = i;
	A = "Hello, World";
	Print( ::X, A );
Print( "done" );
