DecileIbex201
compress addin
I have a script that I want to be able to share and use, however it picks directory from local pc. Is there a way to have a setup file when you first download it and customise to your file path and then keep using this script as an addin?
Re: compress addin
Hi @DecileIbex201,
When you create an add-in that contains a script that you have selected in your local directory, it is 'contained' within the add-in and installed locally on the users PC. You can read more here: https://community.jmp.com/t5/JMP-Add-Ins/Add-In-Guidelines/ta-p/605400
Thanks,
Ben
